Rule Machine App will not open
Hi all -
I was working on a new RM app and must have messed something up and now that I cant get back into the app. Rule Machine works fine for other apps but will not open this new app. I have about 4 hours into the app and would rather not start over. I do not have any restores that will correct the issue.
Thanks!
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: empty String
Not the app but the specific rule right? If the rule will not open you will need to delete it and start over. It's corrupt and will not load. It would be nice if RM did a bit better error checking to not allow that to occur and will roll back to the last valid state should an error be encountered but :man_shrugging:
Yes - just the rule will not open. I will try the copy method before delete.
Thanks!
During RM edit, if I'm not on the desired path, I guess I should just continue and then delete vs hitting <<App list; I think that's what I did. I could not get the rule restored - starting over - a part of the leaning curve I guess.
That is most likely the problem. Both doing that and also hitting the back button in the browser have a very high probability of breaking your rule.
When I work on very complexe rules, I tend to make a copy of it and pause or disable it. With the latest version of the firmware, you can now also export a copy of it. I would do one of those regardless after the complexe rule is finished and working... Just in case...
