I've been trying to make a few simple rules to activate scenes. I get to the point where I'm supposed to pick a scene, I check the box for the scene I want, hit update and nada. The window just goes back to same way it was before the selection.
Is this normal behavior for the new RM 5?
It appears you have screen reader support turned on. If you're not using one, I'd go to "Settings" and turn this off--it's the "Enable screen reading accessibility" at the top and is meant for software like JAWS. If this is intentional, then I assume this would work if you used the software to make the selections (if not, there could be a problem--but this setting isn't meant for point-and-click users like the default setting is).
Thanks. That did it. Don't know how that got on.
