Rule Machine 4 Temperature Comparison
Seems like a perfectly reasonable way to do it to me...
I didn't think anyone used it to be honest. I had that out for months and no one said anything, though I knew about it. LOL
oh shoot... I kinda figured that though, I've been searching for a few days to find something to get my PWS data into any smart home stuff... there's almost nothing to be had.
I also have a weather link live station, that cranks out a json file directly... I'm toying with the idea of going straight to the source as my weewx system gets unstable and stops working now and then.
Mind if I use bits of your driver for that? if I embark on it...?
Sure... I ripped this from @Cobra weather driver as it is... Of course I asked just like you !
It's really nice to see someone like respect others code and ask. It's not a normal thing around here.
Al I ask is that you just add your name to the top of the driver code below mine when you are done.
Could always use node-red to parse the Json and shove the values you want into habitat using maker API...
That is what I do with my weatherflow weather station.
I've moved to doing as many external (not time sensitive) integrations as I can in node-red. Much easier platform to work on, and I control all the logic directly without having to worry about hubs slowdowns, support issues, or other nonsense like that.
Thanks @JasonJoel I am really fresh to Hubitat from Smartthings, this node-red seems like a totally new world to explore.
I did a fresh push for the driver if you want to update... it includes your fix and corrects the UTF8 encoding.
it doesn't seem to exist at the same GitHub URL it did before, can you point me to it?
Thank you!!
I pulled it because it can't be used anymore since @Cobra removed his repository that required it.
oh that's too bad.... I just went digging around and found out why. that's also quite unfortunate.
I'm no expert on license agreements, is it okay to continue using your code? or should I remove it?
Yup you can still use it !
