I have a rule that was set to fire at 9:30pm. A few days ago I changed the rule so that it fires at 9:00pm. Since I made that change, therule is running at 9:20 instead of 9:00... I'm stumped. At 9:24 I tried to re-save the rule in hopes that it would work correctly tomorrow
I see the arrow for restrictions is expanded. Are there any restrictions entered?
The rule doesn’t fire if I’m away that’s the only restriction. The rule is firing just 20 minutes late
If you remove any restrictions, what is the result? I suspect there may be something causing the rule to become false because the restriction is true (eg. the mode is Away) at 9pm EDT.
I’ll remove and report back tomorrow
Look at the app details page, and see what the Scheduled Jobs says.
Is this the screen shot you're looking for?
Strangely enough after removing the mode restriction, it worked tonite, but I don't see another rule firing that would change the mode between 9:00 and 9:20. I've put back the restrictions to see what happens tomorrow
No, the app itself, where you set it up.
So the rule fired at the appropriate time with the same restrictions that were set the other day. I’m happy it’s working... now I have a sensor not reporting motion so on to the next troubleshooting
