Rule button explanation
Can you explain how how this switch or button works. Please use examples
"ignore trigger events while running"
I have 4 separate rules controlling my kitchen using present sensor. 1 ceiling on motion 2 off no motion same for cabinet lighting 3 & 4. Does this part of the rule apply to these triggers?
As I understand it, that option would only be useful in a longer-running rule scenario (involving delays or anything else that can extend execution) where subsequent trigger occurences could throw a monkeywrench in the already-running rule.
In most (arguably) cases, this option wouldn't be necessary, as most rules excute start-to-finish quickly.
In the case of a "motion on/off -> light on/off" rule, this option should not be necessary.
More info here:
This toggle was added for cases where delays are within the actions of a rule. Bruce explains this in this post:
Thanks for all your help. I think I've got it now.
