I Have 2 Thermostats, and have set each of them to use a separate Thermostat 2.0 Scheduler.
I am attempting to set the heat/cool temperature set points via Rule 5.1 using an Action to "Control HSM, Garage Doors, Locks Valves or Thermostats". I then select "Set Thermostat Scheduler" I then Check the box for "T6 Thermostat 1st Floor", I then select "Set Days/Times Setpoints" I then select one of the Preset Time Periods "Wake", and when I click anywhere in the Screen I then get:
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: Cannot get property 'heat' on null object
The logs show this error:
java.lang.NullPointerException: Cannot get property 'heat' on null object on line 5199 (method doActPage)
I cannot do anything to use Rule Machine with the Scheduler 2.0. I've deleted and created new rules, I've changes the name of the Thermostat Scheduler, but the same error is thrown at the same point making it impossible to set the Thermostat schedule in Rule Machine 5.1. I'm on platform version 2.3.3.130 on C-5 Hub.
