I noticed that I have 2 rooms with no devices in them. I can not find a way to get rid of them. Used to be the room would just go away when you moved the last device from it. This is a C7 running 2.4.0.151. They show up in the rooms page but not on the home page.
Looks like there may be a bug. When you click on the room in the grid view the window opens and then disappears. Go into the rooms tab, change to list view, select the room and then remove. If it doesn't work, try reloading the page and try again.
That worked, thought I had tried everything. Thanks.
