if you paste the track uri as the resume track
string and click resume track on the device interface what happens?
hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
nothing
was the player stopped when you tried it?
tried both
also tried it in PlayTrack and it works in there, both with nothing playing and with something else playing
but not in restore track or resume track?
correct
it hard to restore or resume the track when those commands dont work.
definitely! at least it speaks now though so can start to move it from ST
yay!
one more try … instead of the track uri from state use the uri please and see if that works for resume or restore.
x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0
also with the track playing please share the full current states data.
nope nothing
### Current States
* level : **17**
* mute : **unmuted**
* status : **playing**
* trackData : **{"audioSource":"Unknown","station":null,"name":null,"artist":null,"album":null,"trackNumber":"1","status":"playing","level":"17","mute":"unmuted","uri":"x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0","trackUri":"hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8","transportUri":"x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0","enqueuedUri":"x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0","metaData":"BBC Radio 1<\\/dc:title>object.item.audioItem.audioBroadcast<\\/upnp:class>SA_RINCON65031_<\\/desc><\\/item><\\/DIDL-Lite>","trackMetaData":"x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0<\\/res><\\/r:streamContent><\\/r:radioShowMd>\\/getaa?s=1&u=x-sonosapi-stream%3as24939%3fsid%3d254%26flags%3d8224%26sn%3d0<\\/upnp:albumArtURI>x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0<\\/dc:title>object.item<\\/upnp:class><\\/item><\\/DIDL-Lite>"}**
* trackDescription : **BBC Radio 1**
ok. if you use the uri in play track does it work?
yes it does
change this original line:
to:
def uri = musicPlayers.trackData.uri
musicPlayers.playText(str)
musicPlayers.playTrack(uri)
save and try please.
[app:8](http://192.168.1.78/logs#app8)2018-10-31 23:22:42.651:errorgroovy.lang.MissingMethodException: No signature of method: app1541027897033593494689.playText() is applicable for argument types: (java.lang.String) values: [Long time no see Emma, Emma is home.] on line 800 (contactClosedEventHandler)
try musicPlayers.speak(str) instead of playText line.
sorry it did just work i noticed i copied it wrong
and does the track start playing again?
tried this one as well but this does not restore it repeats
this did work but now it also repeats ? when it did restore it didn't seem to restore to the exact correct radio link it restored to a version of it oddly. I don't know how to explain what i mean, but it did say tune in then after it just the radio station with no picture.
also the volume does not increase ( although a good thing now as its late!)
just noticed errors in the SONOS logs
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:34:33.571:errorgroovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[17]] Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() (setLevel)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:34:33.466:errororg.codehaus.groovy.runtime.metaclass.MethodSelectionException: Could not find which method playTrack() to invoke from this list: public java.lang.Object sonosDriver#playTrack(java.lang.String) public java.lang.Object sonosDriver#playTrack(java.util.Map) public java.lang.Object sonosDriver#playTrack(java.lang.String, java.lang.Object) (playTrack)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:30:36.183:errorgroovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[17]] Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() (setLevel)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:30:36.136:errororg.codehaus.groovy.runtime.metaclass.MethodSelectionException: Could not find which method playTrack() to invoke from this list: public java.lang.Object sonosDriver#playTrack(java.lang.String) public java.lang.Object sonosDriver#playTrack(java.util.Map) public java.lang.Object sonosDriver#playTrack(java.lang.String, java.lang.Object) (playTrack)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:29:55.082:errorgroovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[17]] Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() (setLevel)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:29:55.018:errororg.codehaus.groovy.runtime.metaclass.MethodSelectionException: Could not find which method playTrack() to invoke from this list: public java.lang.Object sonosDriver#playTrack(java.lang.String) public java.lang.Object sonosDriver#playTrack(java.util.Map) public java.lang.Object sonosDriver#playTrack(java.lang.String, java.lang.Object) (playTrack)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:28:17.487:errorgroovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[17]] Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() (setLevel)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:28:17.422:errororg.codehaus.groovy.runtime.metaclass.MethodSelectionException: Could not find which method playTrack() to invoke from this list: public java.lang.Object sonosDriver#playTrack(java.lang.String) public java.lang.Object sonosDriver#playTrack(java.util.Map) public java.lang.Object sonosDriver#playTrack(java.lang.String, java.lang.Object) (playTrack)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:27:41.906:errorgroovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[17]] Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() (setLevel)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:27:41.797:errororg.codehaus.groovy.runtime.metaclass.MethodSelectionException: Could not find which method playTrack() to invoke from this list: public java.lang.Object sonosDriver#playTrack(java.lang.String) public java.lang.Object sonosDriver#playTrack(java.util.Map) public java.lang.Object sonosDriver#playTrack(java.lang.String, java.lang.Object) (playTrack)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:25:25.961:errorgroovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[17]] Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() (setLevel)
[dev:67](http://192.168.1.78/logs#dev67)2018-10-31 23:25:25.896:errororg.codehaus.groovy.runtime.metaclass.MethodSelectionException: Could not find which method playTrack() to invoke from this list:
