I have had this Room LIghting instance working very well for six months to a year. Recently my schedule changed, and since I updated it (really only shifted some days around, I didn't change the guts of the rule) it has been very wonky.
Among issues I am having , if I turn a light off, it will immediatly come back on, even if the (virtual) Bypass switches are off . For the most part the by pass switches have disabled the motion activation, not what I really wanted , but it was close enough to keep the wife happy. Maybe I just need a fresh set of eyes to find something I'm missing.
You will need to look closely at the logs produced by Room Lights to understand what is going on. The app as you've posted it here is Disabled, so in theory it won't do anything at all until re-enabled. Logs are your friend, and the only way anyone can help figure it out.
It sounds like there might be a conflict in your automation logic, possibly from overlapping conditions or an old rule still triggering. Double-check any dependencies between your motion sensor, bypass switches, and schedule changes. Also, try disabling the rule temporarily and re-enabling it to reset any lingering issues.
