I have an issue where my kitchen lights do not always seem to turn off, two nights in a row, but given I am a totally newbie it could be something I have done.
I compared the Kitchen RL parameters with another room that seems to work ok and found one key difference - the kitchen did not have a transition time set. The Kitchen consists of white ambient bulbs and colour bulbs and the other room has just colour bulbs. All managed through Cocohue and the Hue hub, all bulbs are Hue.
So I tried to set a transition time and there was no facility for me to enter a transition time at turn off, only at turn on.
I then tried cloning the room that works to the kitchen and the transition time at off became the delay time.
When I was setting up room lighting in other rooms, the kitchen was one of the last I did, I had observed on another set an activation and turn off issue that seemed to be fixed by setting the transition time.
So not sure if this is how it is supposed to work or if it something I have done, The lights were on at 05:00 this morning and the details of setup and the log taken at that time are below. Kitchen light switch V is a virtual switch to facilitate multiple ways of turning on or off the lights and was not invoked in this period.
app:1012023-08-05 12:37:58.469 AMinfoIgnored Turn Off Event: 'Kitchen Sensor 1' illuminance 1 not > 500
app:1012023-08-05 12:37:58.457 AMinfoAlready Activated
app:1012023-08-05 12:37:58.454 AMinfoActivation Event: 'Kitchen Sensor 1' illuminance 1
app:1012023-08-05 12:30:02.339 AMinfosetColorTemperature: Kitchen spot 3, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:02.274 AMinfosetColorTemperature: Kitchen spot 2, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:02.223 AMinfosetColorTemperature: Kitchen spot 10, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:02.191 AMinfosetColorTemperature: Kitchen spot 1, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:02.059 AMinfosetColorTemperature: Kitchen spot 4, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:01.941 AMinfosetColor: Island 2, level: 50, rate: 5, hue: 11, sat: 20
app:1012023-08-05 12:30:01.869 AMinfosetColor: Island 1, level: 50, rate: 5, hue: 11, sat: 20
app:1012023-08-05 12:30:01.700 AMinfosetColorTemperature: Kitchen spot 9, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:01.541 AMinfosetColorTemperature: Kitchen spot 8, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:01.422 AMinfosetColorTemperature: Kitchen spot 7, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:01.351 AMinfosetColorTemperature: Kitchen spot 6, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:01.228 AMinfosetColorTemperature: Kitchen spot 5, temp: 2203, level: 47, rate: 5
app:1012023-08-05 12:30:01.083 AMinfoAdjusting for Dream
app:1012023-08-05 12:30:01.057 AMinfoActivation Event: 'Otto Hubitat' mode Dream
app:1012023-08-04 10:18:36.643 PMinfoIgnored Turn Off Event: 'Kitchen Sensor 1' illuminance 10 not > 500
app:1012023-08-04 10:18:36.627 PMinfoAlready Activated
app:1012023-08-04 10:18:36.625 PMinfoActivation Event: 'Kitchen Sensor 1' illuminance 10
app:1012023-08-04 10:13:38.682 PMinfoIgnored Turn Off Event: 'Kitchen Sensor 1' illuminance 0 not > 500
app:1012023-08-04 10:13:38.636 PMinfosetColorTemperature: Kitchen spot 3, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.566 PMinfosetColorTemperature: Kitchen spot 2, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.498 PMinfosetColorTemperature: Kitchen spot 10, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.429 PMinfosetColorTemperature: Kitchen spot 1, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.364 PMinfosetColorTemperature: Kitchen spot 4, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.302 PMinfosetColor: Island 2, level: 50, rate: 5, hue: 11, sat: 20
app:1012023-08-04 10:13:38.224 PMinfosetColor: Island 1, level: 50, rate: 5, hue: 11, sat: 20
app:1012023-08-04 10:13:38.165 PMinfosetColorTemperature: Kitchen spot 9, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.110 PMinfosetColorTemperature: Kitchen spot 8, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.058 PMinfosetColorTemperature: Kitchen spot 7, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:38.005 PMinfosetColorTemperature: Kitchen spot 6, temp: 5525, level: 94, rate: 5
app:1012023-08-04 10:13:37.955 PMinfosetColorTemperature: Kitchen spot 5, temp: 5405, level: 94, rate: 5
app:1012023-08-04 10:13:37.884 PMinfoActivating for Dusk
app:1012023-08-04 10:13:37.845 PMinfoActivation Event: 'Kitchen Sensor 1' illuminance 0
app:1012023-08-04 10:09:36.794 PMinfooff: Kitchen spot 3
app:1012023-08-04 10:09:36.725 PMinfooff: Kitchen spot 2
app:1012023-08-04 10:09:36.657 PMinfooff: Kitchen spot 10
app:1012023-08-04 10:09:36.593 PMinfooff: Kitchen spot 1
app:1012023-08-04 10:09:36.531 PMinfooff: Kitchen spot 4
app:1012023-08-04 10:09:36.472 PMinfooff: Island 2
app:1012023-08-04 10:09:36.414 PMinfooff: Island 1
app:1012023-08-04 10:09:36.358 PMinfooff: Kitchen spot 9
app:1012023-08-04 10:09:36.306 PMinfooff: Kitchen spot 8
app:1012023-08-04 10:09:36.255 PMinfooff: Kitchen spot 7
app:1012023-08-04 10:09:36.207 PMinfooff: Kitchen spot 6
app:1012023-08-04 10:09:36.160 PMinfooff: Kitchen spot 5
app:1012023-08-04 10:09:36.111 PMinfoMotion Stays time over
app:1012023-08-04 10:06:23.666 PMinfoIgnored Turn Off Event: 'Kitchen Sensor 1' illuminance 10 not > 500
app:1012023-08-04 10:06:23.651 PMinfoAlready Activated
app:1012023-08-04 10:06:23.645 PMinfoActivation Event: 'Kitchen Sensor 1' illuminance 10
app:1012023-08-04 10:04:36.052 PMinfoAll motion inactive, scheduling off in 5 minutes
app:1012023-08-04 10:04:36.049 PMinfoTurn Off Event: 'Kitchen Sensor 2' motion inactive
app:1012023-08-04 10:03:40.282 PMinfoNot turning off, some motion still active: Kitchen Sensor 2
app:1012023-08-04 10:03:40.278 PMinfoTurn Off Event: 'Kitchen Sensor 1' motion inactive
app:1012023-08-04 10:03:30.310 PMinfoAlready Activated
app:1012023-08-04 10:03:30.309 PMinfoActivation Event: 'Kitchen Sensor 1' motion active
app:1012023-08-04 10:03:26.424 PMinfoNot turning off, some motion still active: Kitchen Sensor 2
app:1012023-08-04 10:03:26.420 PMinfoTurn Off Event: 'Kitchen Sensor 1' motion inactive
app:1012023-08-04 10:03:08.405 PMinfoAlready Activated
app:1012023-08-04 10:03:08.404 PMinfoActivation Event: 'Kitchen Sensor 2' motion active
app:1012023-08-04 10:03:07.620 PMinfoNot turning off, some motion still active: Kitchen Sensor 1
app:1012023-08-04 10:03:07.617 PMinfoTurn Off Event: 'Kitchen Sensor 2' motion inactive
app:1012023-08-04 10:02:37.032 PMinfoAlready Activated
app:1012023-08-04 10:02:37.027 PMinfoActivation Event: 'Kitchen Sensor 2' motion active
app:1012023-08-04 10:01:16.749 PMinfoMotion active 'Kitchen Sensor 1', canceling scheduled off
app:1012023-08-04 10:01:16.747 PMinfoCancel Turn Off Event: 'Kitchen Sensor 1' motion active
app:1012023-08-04 10:01:16.735 PMinfoAlready Activated
app:1012023-08-04 10:01:16.732 PMinfoActivation Event: 'Kitchen Sensor 1' motion active
app:1012023-08-04 10:01:14.684 PMinfoAll motion inactive, scheduling off in 5 minutes
