Room Lighting Group with Wiz lights activation issue
I have an issue with using a RL group that is a few Wiz lights. I'm on 2.3.7 and using the built in Wiz integration (not Matter).
The Activator does not set the levels to the expected values on the first activation. A 2nd activation gets the lights to where they are supposed to be.
At 'Off':
First Activation:
Second Activation:
Using the 'Force' option doesn't make any difference.
When activating you can see the CT values move, but on the first activation they don't stick at the proper level. Also, a display issue: the live update of values isn't always correct, a refresh fixes them.
