Looking for advice regarding Room Lighting. There are instances where a Room Lighting group may be turned on (or off), and then subsequently some portion of the included lights may individually be turned off (or on). Since the Room Light Activator is in the on position, if someone tries to turn all the lights on using the Room Light Activator, it will fail because it is already on. Is there a way for the Room Light Activator to essentially ignore the current state and essentially reset all the included devices to their intended state when the Activator is pressed on?
TIA for any thoughts or advice.
