C7 hub. 2.4.2.157. I woke up to my motion activated lights not working. Hubitat says it was disabled, which it wasn't manually disabled. The means to activate were all met, and the restrictions were not. I am confused, and Ive noticed this happening with room lighting recently. Then I click activate, the lights go on, and its activated and disabled. Logs say app:4402025-10-17 05:29:19.639 AMinfoIgnored Activation Event: 'kitchen motion sensor' illuminance 6
When you use the option to "Disable" it upon X events, dont you also need to set up how it gets enabled again? So you have it getting disabled in Away but there is nothing to enable it again.
I would remove that option and move it to the "Limit Actvation..." section, and select the Away mode there.
That was it. The reason it has worked for a few weeks, was that our phone presence sensors haven't been working right, so it was never set to away mode. Thank you.
