Room lighting clarification
Hello.
If I’m building a room lighting automation where I want the lights to turn on and then off after x minutes except when a outlet detects a certain amount of power draw, then I want the lights to stay on does it make more sense to put the power draw attribute under “limit when Turning Off can occur” or “Disable Turning Off upon these Events” with a “ Re-Enable Turning Off upon these Events” set to when power draw drops below the amount again.
Once power draw drops and no Motion is detected, I do want the lights to turn back off. As far as I can tell doing either of these will get the same result? Am I missing something?
Thanks in advance.
