Anyone know what happened to my room lighting app that’s not allowing me to access it?
Notice how it’s greyed out?
Had to do a database restore to get back into this child app. Resolved.
I was able to recreate this with another room lighting app. Wondering if this is a bug.
I was working on my iPhone but saw the behavior using Edge while using my laptop as well.
When creating a new room lighting child app, select setup lighting periods or recapture device. Select time period. And click + on adding a time period. Click the browser back button. If you have a done button, click done. Everything should be greyed out. With only option to remove which doesn’t do anything.
Do you see anything in the logs?
That's the problem. Like Rule Machine, you should avoid clicking the Back button in your browser when you're in the middle of something. In your case, either add the time period or use the "Cancel" button if you've changed your mind. (If it's not too late, you can use the forward button to go "back" here and fix things.)
There might be something @bravenel could do to make this be handled more gracefully (or if not maybe some long-term enhancements at the platform level to make this kind of thing easier for apps), otherwise the above is why it's happening for you.
After clicking back on apps from the main menu I saw it listed as a child app, opened and then clicked on remove and was able to remove it.
No biggie I guess, just wanted to report it is all.
