RM5.1 Global Variables
I created a global Boolean variable that I need to set from a rule. In the new RM I do not see set variable anymore in the Set Variable, Mode or File, Run Custom Action group. What am I missing?
Did you create a global variable or a hub variable? Global variables would now be under Rule Machine Legacy and are not accessible from "new" Rule Machine. Hub variable are under Settings and are accessible from "new" Rule Machine and an increasing variety of other apps (one of the reasons this change was made, elevating them to hub-level status instead of mostly a Rule Machine feature).
Oh OK, I got it, thank you.
