136 is broken. We will get a fix out.
Could you show that rule, and also you cut off the left side of the logs screenshot. This may be unrelated to the other thing with 136.
Thank you
Ping always returns zero
RPi4 is PingData(rttAvg: 0.0, rttMin: 0.0, rttMax: 0.0, packetsTransmitted: 0, packetsReceived: 0, packetLoss: 0)
Packetloss = 0 normally says that the device responded without any issues, but when the packetsTansmitted is also zero my driver handles it as a no response received. (The system call started doing that occasionally with 2.2.7.121 - never could determine the pattern)
@starcom are you on a C-7 or ??
C5 running 2.2.9.137
Fix will be on next build
Thank you
