Hello,
I'm having a problem where I have two rules that seem to speak to sonos a line that is not in either rule.
I'll explain
1- Rule "Front Door Bell -2"
This rule monitors a hue motion sensor on the porch and then plays a chime and announces "someone at the front door" on a sonos one sl.
2- Rule "Garage Door Loop 2". This rule monitors an ecolink tilt sensor to see if the garage door opens. If so it will chime and say "Garage door is open" on the Sonos one sl.
The problem: Both of these rules, at random, will announce "Garage Door Is Open". The Front door rule should never announce this, and the Garage door rule should only announce it once.
So what will happen is when the motion sensor is triggered, the rule will work like it's supposed to but there will be an "Garage Door Is Open" on the sonos right after it says "someone at the front door"
AND when the garage door opens, it will randomly say "Garage Door Is Open" twice in quick succession.
I can't seem to find the problem. I've even rewritten these rules in RM5.1 and stopped the old ones in RM Legacy.
At this point I've got most of my rules Stopped. The phrase "Garage Door Is Open" only appears in one rule, and that is the Garage Door Loop 2 rule.
I've captured the log from each of these rules, today when this issues came up again. The problem is the logs for the Front Door rule, NEVER show that "Garage Door Is Open" is ever spoken, yet I hear it.
The logs for the Front Door Rule are in two pics, I've skipped a small part where I flash the sengled bulb.
And the log for the garage door rule:
Are the rules inside hubitat written as scripts? Is there a way I can ssh into it and maybe grep out that string to see where it exists?
Any help would be greatly appreciated.
zm
