Just wondering if RM could have multiple thermostat control added to it when defining an activity? Currently it lets you select multiple thermostats to apply temperatures to but the issue is all thermostats have the same temperature applied. I was thinking something like bulbs brightness per mode? ie select multiple thermostats and each one then spawns a set of heat/cooling options? This would be super useful especially in zoned properties where you would one one zone different to the other for nighttime temperatures
+1 to this I've had to make a separate RM rule for each individual thermostat even though the conditions are the same
