RM Presence Trigger not working 1.1.3
@bravenel Bruce,
Hoping you can either explain what I am doing wrong, or confirm a bug in RM. I am trying to make use of the new %device% and %value% feature for notifications and speech firmware v1.1.3.112. I deleted my original PRE v2.5 rules (just simple Triggers, one for Presence Arrival and one for Presence Departure.) I created a new Trigger (no rule) as show below, however it never seems to trigger and take action.
(Note: I would normally have three presence devices in the following Trigger. Trying to keep it as simple as possible.)
The following Rule works, however it sort of defeats the purpose of creating a generic rule for multiple presence devices as I would need one for each device (correct?)
Any insight would be appreciated.
I can confirm that this RM rule doesn't work either. My work-a-round is to use HSM and just setup a "custom rule" using the presence sensor(s) as the trigger, work's perfectly using the %device% %value% method.
On a side note, I observed the logs while trying this with RM and see the trigger being detected but the action using pushover shows no message sent at all.
@bravenel @halfrican.ak
So, I updated my hub to the latest 1.1.3.113 firmware release from today. Afterward, my Trigger in RM is now working.
Not sure if the new firmware fixed it, or if restarting the hub fixed it.
I hadn't tried it with the latest hot-fix either, should have mentioned that.
It was the bug referred to in the release notes for 1.1.3.113.
Thanks Bruce.
