When importing an existing RM rule, it seems like the import app matches the device ID to prepopulate the devices..
I would like to make a feature request that when a "Restore" is being done, then it may may match the ID, but when "Importing" it should try to match the device name/label rather than the ID, or maybe even better would be a toggle switch somewhere we could pick if we wanted to match the id or the name/label to pre-populate the devices..
This would make importing a rule much faster and less error prone, and since the import is matching it already, and leaving blank when no ID found.
Just a suggestion !
