RM hub variable issues
@bravenel
I have noticed a couple of issues with Rule Machine and hub variables.
If you view where a hub variable is used it does not display the full rule title if the title contains a colon.
Screenshot 2022-01-02 at 13.29.53
Unlike when you see where it is also used on the variable deletion prompt.
Screenshot 2022-01-02 at 13.30.07
This leads to the second issue when a rule has been cloned and modified to reference different hub variables there are still references in the setting tab of the variables that have been removed.
Nothing major, but thought I would raise them.
  • D
Maybe it's classed as one of the 'special characters' that should not be used.
It isn't listed though. :man_shrugging:
DO NOT use these characters: ' " \ ~ [ ] < > in Hub Variable Names
Ha, good idea. Probably something somewhere is catching on the colon in the name, although the name works, evidently, in other contexts.
