RM Example: Heater Control with hysteresis
I have a space heater I run at night, that I Control the setpoint with the temperature from a virtual thermostat.
I want the heater to heat .25 degrees above the thermostat setting and turn off, and then turn back on when the temperature drops to .25 below the thermostat setting,
This is great.
I have several humidifiers that I want to automate turning on/off. I thought I would need more than one rule to create upper and lower setpoints like this, but thatā€™s because Iā€™m not very good with this kind of logic building. I see though how it works in your screenshot. I posted a shot of a rule I just created, this should work the same way, right?
Thanks!
It should work,
