Trying to set up a simple rule to put a GET response into a string variable:
Running the rule with logging on shows this:
...but the value of the "response" variable never changes.
Hmmm... Me too, or at least it didn't change initially, then I updated the rule to turn logging on and the variable is now "empty".
Was yours a Hub Variable?
Admittedly for this use case you could use Hub Info, but that may be a little "heavy" for whatever you may be wanting to achieve.
I have tried it with both a hub variable and a local variable - in both cases, the GET erases whatever was in the variable.
...and yes, I also use Hub Info, but I really don't want/need all of that info.
I will look into this.
I found the cause of this, and it will be fixed in the next release. It was indeed trying to slam a null value into the string variable. After the fix it puts the data value from the response into the variable, and that works.
Awesome. Thanks!
