I have set up a Nokia Sleep on my bed, and am attempting to use it to trigger my Night mode change when going to bed, and Day mode change when getting up. It is linked through IFTTT, which merely turns the Sleep Switch in Hubitat on or off. I have two RM's for this:
Maybe I'm blind and missing a difference between the two rules (other than forgetting my Pushover notification on the Day mode...), but I honestly don't know what the difference is.
The first thing to try would be to remove the restrictions, and see if it works. I don't see why it isn't working, unless one of those restrictions failed. RM logs every event that a rule gets, so see if it logs anything.
Also, these could both be triggers instead of rules. Any rule that has a single condition and only actions for true, might as well be a trigger.
i was looking at some triggers last night, but it doesnt look like it can be set to cancel on truth change, only wanting them to run if ive been laying in bed for >= 5 minutes.
I haven't seen anything under app logs, is there a setting to enable them, or are you only referencing the live logging?
Triggers don't have cancel on truth change, because they don't have truth -- only events that trigger them. To get cancel on truth change you need a rule.
