RM 5.1 - Calling "Pause Rule" is actually toggling the pause state
Every time I run "Pause Rules: TEST", it toggles TEST's state between paused and unpaused. I would think if TEST is already paused, it should remain paused if "Pause Rules: TEST" is called. You poor guy, I feel your pain :slight_smile:
I would have assumed the same, but I just ran a small test and saw the same thing. @bravenel is this expected behavior?
Um, isn’t there a typo there? If you want to tag Bruce, I believe you need to say:
There is. thanks. The space got deleted.
This will be fixed in the next release.
