I wanted to run a rule that will only run between sunset and sunrise.
I selected "Between Two Times", and now presented with "Start time" and "End Time".
I don't really care when it start/end, as I trust for HE to identify when is my sunset and sunrise time.
The question is, how come I am asked to populate "start time" and "end time"? what's the purpose of it?
When I tried to add it, the system thrown the following error:
I‘ve just tested this and it works as expected for me. In that, it is only displayed when “A Specific Time“ is selected, otherwise it displayed offset.
I’m on 2.3.0.120, I only see
Fixed bug with Between Two Times in Wait.
in the initial 2.3.0 release and nothing else about between two times.
What version are you running?
It is a bug. The start-time/end-time is only applicable when using a specific time. Anything you enter in that field when using Sunset/Sunrise is ignored. I'm having the same issue with Time of Day. If I specify Sunrise (or Sunset), I get the mandatory Start-Time field. Once I enter something (doesn't matter what), that field clears, I get the Offset box. I'm also on the latest version 2.3.0.120 with the C-7 hardware.
