Rm 4 rule doesn’t work in rm 5 - simple rule
I have a rule which cancels a dimmer fade if the lamp turns off. Works in rule machine 4 however when done in 5 it’s doesn’t. Any ideas?
I see you have different devices as triggers so the rules aren't exactly the same. Are you sure the second device actually sends a "physical" off event, and, along those lines, do you care about physical vs. digital off? If not, just use a regular "Switch" capability for the trigger. If you do, then verify actual device events or enable at least event and action logging for the rule so you can see what it's doing when, if ever.
Thanks, I’ll give that a go :+1:
