I've been playing with RM 4.0, and things don't seem to work the way I expect them to. I'm trying to set up a temperature alarm, something that will notify me if the temperature at a specific location goes to 78 degrees or above. I got that working, then decided it would be nice to get a periodic notification as long as the temperature is above 78 degrees, just in case I missed the first one. So I added a Repeat, and that's where the problems started.
My approach to this is to have a rule that turns a virtual switch (Temp Warning Trigger) on if the temperature goes about 78 and to turn the switch back off if the temperature goes below 78. Then I have a second rule that announces "It's Hot." every minute when that switch is on (this will be changed to every 30 minutes or 1 hour once it's working.) The first rule controlling the virtual switch seems to work fine, my issue is with the second rule to do the announcement.
For the second rule I set the trigger to Temp Warning Trigger changed, and the action is IF Temp Warning Trigger is ON, then repeat every minute an announcement that It's Hot, ELSE Stop Repeating Announcements.
If I manually turn Temp Warning Trigger ON, I immediately get an It's Hot announcement, and it repeats every minute. But if I manually turn Temp Warning Trigger OFF, the announcements continue, even though I see the Stop Repeating Actions in the log. What am I missing here?
Here's a screenshot of my High Temp Announce rule:
And here's a screenshot of the logs:
What am I missing? Why did the Stop Repeating Actions not stop the repeating action?
Thanks,
Russ
