@bravenel
I am trying to set per modes for a group of lights (previous I have only done for a single bathroom light).
I want it so if the light is turned on at say full brightness but the per mode setting is 10, it should adjust it to 10. It seems to work if I turn the light on from the hub by changing the level. If I just turn it ON at whatever the existing level is, the RL is not adjusting the level to the current setting.
I want to turn on the Activate only Activating Switch option also but I have it off right now trying to troubleshoot this possible issue. EDIT: Just tested this setting again and with Activate only Activating Switch turned on I cannot reproduce screenshot #2 below at all, no matter what I do it looks like #1, it says it is activating but then does nothing.
Am I doing something wrong?
#1 Turn on to existing level
#2 Turn on with setLevel (level changing from prior)
