@bravenel First I noticed tonight the mode had changed and the lights were not adjusted automatically. Possibly due to me installing the update and rebooting. This worked yesterday with v138. Then I tried pressing activate on the rule and nothing, it said activating in the logs but does not do anything. If I turn on the force option and check all the lights then it will adjust the level when I press activate.
Current mode, Center Light I set to 100, the RL app picked up the event somewhere I saw it.
Mode changed to 4-Night and it changed the level now that I have the force option enabled
Not sure why it went to not Active at the very end there, but everything is set how it should be.
Looks like that did the trick for setting the level. It adjusted the level on mode change and also if I manually activated. I will leave the indicator option off for now.
