Ring Keypad v2 - Detect Fire/Panic/Medical
I am trying to write a small app to detect Ring v2 panic buttons and set a virtual switch. In my app, Using the securityKeypad capability and subscribing to attribute securityKeypad, I am able to see normal arming/disarming events, but the panic buttons events aren't being detected that way.
Am I using incorrect capability or subscribing to wrong attribute?
In the logs, when panic button is pressed, the following appears:
dev:2632021-02-19 08:55:20.877 am debugEntry control: [sequenceNumber:161, dataType:2, eventType:17, eventDataLength:0] keycache:
dev:2632021-02-19 08:55:20.873 am debugSupervision Get - SessionID: 51, CC: 111, Command: 1
dev:2632021-02-19 08:55:20.862 am debugparse:zw device: 29, command: 6C01, payload: 33 06 6F 01 A1 02 11 00 , isMulticast: false
An alarm disable event looks like this in the logs:
dev:2632021-02-19 08:55:15.467 am debugfound code: $$$$ user: $$$$
dev:2632021-02-19 08:55:15.463 am debugEntry control: [sequenceNumber:160, dataType:2, eventType:3, eventDataLength:4] keycache: $$$$
dev:2632021-02-19 08:55:15.460 am debugcharacter 7, value 55
dev:2632021-02-19 08:55:15.456 am debugcharacter 6, value 55
dev:2632021-02-19 08:55:15.452 am debugcharacter 5, value 50
dev:2632021-02-19 08:55:15.449 am debugcharacter 4, value 53
dev:2632021-02-19 08:55:15.444 am debugSupervision Get - SessionID: 50, CC: 111, Command: 1
dev:2632021-02-19 08:55:15.439 am debugparse:zw device: 29, command: 6C01, payload: 32 0A 6F 01 A0 02 03 04 35 32 37 37 , isMulticast: false
I think the simple answer is yes.
The driver for Ring Keypad v2 doesn't seem to be written to recognize any of those special buttons. Once that is updated then you would be able to subscribe to the device event and wait for that event to occur.
Thanks. I'm new to Hubitat and groovy, but have a coding background. Appreciate the assistance.
No worries.
As I understand it this has been brought up before and someone mentioned that it wasn't supported yet.
Adding @bcopeland to see if he has any further info on it.
I did contact support to see if they’d supply the driver source - probably peeing in to a strong wind on that......
See my thread here about this...
:wink:
@capnlarsfl, Welcome to Hubitat!
Hi Bryan - I saw that post. Haven’t had trouble pairing. But your App Library gave me an idea to try your event watcher app. Next weekend....
