That is a big issue for me. Mine are used all over.
Migration could be a real pain.
I'm hoping I can leave the old devices in place while I swap in the new ones, if I migrate.
I am sure there are better ways, but here is what I did for my devices. (1) I left the Unofficial Ring Integration up and running as informal, (2) I added the new Ring Integration alongside, so now I have every device in duplicate inside Hubitat, and (3) I went to each of the old device’s “In Use By” page and pulled up each rule and then replaced the old with the new. Finally, (4) once I was comfortable everything was stable, I turned off the Unofficial Ring integration and removed the old devices. It was daunting at first (I have about 40 total devices but really about 10 devices were ‘rule-heavy’). I’d guess the rule-moving process was under 1 hour total.
Someone can now chime in and tell me about a way to do this all automatically….
Early on I read that there was a limitation that you could not have the official app running concurrently with the unofficial app. By the time he did do so would result in unreliable notifications.
Has this limitation been eliminated or did you simply live with unreliable notifications until you completed your migration.
Thanks!
Marc
I remember reading that as well. I had both running for about 1-2 weeks without any issues on notifications. I don’t know the official stance on that but it worked fine for me and let me get comfortable with the new integration first. Of course, YMMV.
@support-agent @bcopeland Any comments on running the "unofficial" and Built-In Ring apps at the same time for a brief period while migrating between them?
Thanks!
No issue running "unofficial" and "official" concurrent for several months.
I've been trying to get an answer to this question for a while but can't get a response. It's the only thing keeping me from getting away from the "unofficial".
I just installed the beta and it is does appear to be working properly even with both integrations installed.
Unfortunately, in the official integration, motion alerts from Keypads are not working but motion alerts from motion detectors are working.
In the unofficial integration, motion alerts work for both keypads and motion detectors.
Are motion alerts for keypads working for anyone else out there?
Marc
There are certainly gaps between what the official integration and the unofficial integration can do so I've been running both side by side and keeping some devices active in one or the other. I've tried messaging @bcopeland directly about further Ring Integration development but haven't heard anything back. I assume he's working on an update and we will hear something when it's ready or he's busy with other projects. Hopefully there is more to come though.
Hi @DiverRich at some point the Hubitat team stopped responding to posts in this thread. I think it was a couple of months ago.
I interpreted that to mean that they were pulling back from further developing this integration, which was re-enforced when I tried it again yesterday and motion alerts on keypads were still not working.
Perhaps my inference was wrong. Have you seen further progress on the integration subsequent to the Hubitat team stopped engaging on this thread? If so, that would build my confidence that these issues will be resolved over time.
Thanks!
Marc
I haven't. In fact, I've seen the opposite. I'm hoping there will be further progress and I'm giving the devs the benefit of the doubt, but it's been a long time since I've seen anything on here from them.
I just checked the release notes and the last time any updates related to this integration were documented was release 2.5.1.138 on July 29 -- 3 months ago. This is consistent with your experience.
I am not going to invest any more time into migrating until I see some of the existing issues addressed. Hopefully they will be able to get back to it sometime this year.
Marc
Installed the latest version and tested today (clean HE install with latest HE firmware), I have a V1 Ring alarm with a few contact sensors, keypad, chime, extenders plus 4 cameras and a doorbell. All have appeared as expected in the HE device list with the location.
If I set the Ring alarm to "away" using the Ring app, the HE "Alarm base station" device state "Alarm mode" reflects the current mode of the Ring alarm, so that works great.
The issue is that if I then trigger the Ring alarm by activating one of the Ring motion sensors the Ring alarm sounds the alarm correctly, but the HE "Alarm base station" device state "Alarm" remains as "off" whereas I was expecting it to change to "siren" or something other than "off" so that I can use it as a trigger.
Is this the correct way to detect in HE that the Ring alarm has been activated, or should I be using an alternative mechanism?
