The integration works fantastic.
You can also easily hook up non-alarm Ring devices through Alexa or IFTTT as well.
You beat me to it.. Yes it works great. Very impressed.
Thank you, thank you.
I consider myself a relatively competent computer user but spent five hours getting my Ring devices into Hubitat this morning. I wish some Hubitat expert would walk through the steps in a YouTube video. If a new Hubitat user has never created/activated a user-created Hubitat App (the Hubitat Package Manager, which is the first step), the "how to" documentation on getting this to work could be better in my opinion.
The final result looks pretty good, however, and I now have my 10 Ring devices created in Hubitat.
Ring Doorbell 2 Pro (1)
Ring Indoor Cam (1)
Various Ring Alarm Devices (8)
- Contact Sensors (4)
- Motion Sensors (1)
- Range Extender (1)
- Keypad (1)
- Hub (1)
Let me know if you are interested in the series of steps I personally followed. Getting my 13 Insteon devices into Hubitat is my next big challenge.
The first post explains the installation steps.
Hubitat documents
https://docs.hubitat.com/index.php?title=Hubitat_Elevation_Documentation
PLEASE, I just got my Hubitat today and I'm reading all of these posts in the forum and I can't for the life of me figure out how to add Hubitat Package Manager. I don't know what it means or why the code I'm importing isn't showing up. I just want to be able to add user apps like the ring integration and any else I find, but I don't know how to add anything.
The installation steps in the first post for are out of date, provided you are willing to use the much easier Hubitat Package Manager to achieve Hubitat/Ring integration.
To start, I believe you need to add the Hubitat Package Manager, which is a user-defined app you will need to create and activate. The first step is to select "<> Apps Code" on the Hubitat main menu and then "+ New App" in the top right corner. That will open up a new window where you can copy and paste the code you need.
You can get the code from this file:
When you successfully save the file, you should see the file named "Hubitat Package Manager" being shown in your "<> Apps Code" window. That means the file has been saved as a user-defined app in Hubitat.
The next step is to actually activate your user-defined app in Hubitat. Select "□□□+ Apps" on the Hubitat main menu and then "+ Add User App" in the top right corner. You should be able to select "Hubitat Package Manager". If you are successful and activate the app, you should now see "Hubitat Package Manager" as an available app in your Hubitat "□□□+ Apps" window.
Let me know if you encounter any trouble (jaxgab@comcast.net).
This post should be useful for you, I included an animated gif/walkthrough as well.
I have already integrated my Ring Alarm devices with Hubitat using the Hubitat Package Manager, but now I now have purchased and installed a second Ring Alarm keypad and wonder how to get that device to show up in Hubitat.
The second keypad doesn't show up in Hubitat automatically, so I am looking for advice on how to proceed.
I believe you need to go into the "Ring Virtual Alarm Hub" on the devices page, and click "Create Devices".
When I click that "Create Devices" button, nothing seems to happen. I go back to the "Devices" list, the second Ring Alarm keypad still has not been added.
Hmm, that should have worked? Perhaps try "refresh" then "Create Devices"?
I don't know if this app is hard coded to only one keypad or not, but I've successully added new Alarm devices this way like the Smoke/CO detectors.
Yeah strange. I added 4 contact sensors the other day this way with success. I don't have new keypad but do have 2 in the system. I guess I could delete one and try adding it back to see if it will work but is that the same?
I realized tonight that my Hubitat/Ring integration is suspect because Hubitat and Ring don't seem to be communicating at all. It is probably why my "Create Devices" button doesn't respond. Unfortunately, when I test my virtual Ring contact sensor in Hubitat it now keeps reporting "contact : closed" even when I open and close the door.
I decided to try uninstalling the "Hubitat Ring Integration (Unofficial)" package in Hubitat Package Manager, then try and reinstall it. It encountered the following error,
Due to the error, I decided to try restoring a backup version of my Hubitat hub, and everything seemingly goes back to "normal". But Hubitat and Ring still don't seem to be communicating at all, even though there was communication a week ago.
Is my Hubitat hub already broken?
I doubt it's your Hubitat, sounds like perhaps your Ring integration is broken, or you access code changed, or something else.
I'd suggest making a backup then manually deleting this app from the "Apps code" and the devices drivers you have from this integration from "Drivers code" and then install again (manually or from HPM, up to you).
I restored a backup version of my Hubitat hub (a very early version) and basically started over from scratch. I was then able to reinstall the "Unofficial Ring Connect" and get all of my Ring devices apparently reconnected with Hubitat on 01/13/2021.
The Ring Door Sensors and the Ring Motion Sensors are all connected and will communicate updates back to Hubitat as I expect.
The Ring Doorbell Pro 2 and Ring Indoor Cam both haven't had any activity since 01/13/2021, so these two devices are essentially useless right now. The Doorbell is being shown as a "Ring Virtual Camera" while the Indoor Cam is being shown as a "Ring Virtual Camera with Siren". Do you have any ideas what may be wrong?
The Ring Alarm Hub seems to be connected OK and is getting regular updates from Ring. I can set off the Ring Alarm Siren in Hubitat but I am not able to change the Ring Alarm mode in Hubitat (i.e. change from "Disarmed" mode to "Armed-Home"). Aren't you supposed to be able to change the Ring Alarm mode in Hubitat?
Sounds like your IFTTT connection is broken which is what tells your HE that there is motion.
The alternative is you could use a HTTP Momentary switch and expose that to Alexa and then have alexa "switch it" when motion occurs if you want to avoid IFTTT.
Yes. I'm doing that right now. @Sebastien has great instructions here.
Thanks for your help and timely responses. I finally got it to work with IFTTT last night, but I really don't like the idea of spending $ 48 per year on IFTTT for applets to get the Ring Doorbell ring events, the Ring Doorbell motion events and the Ring Indoor Cam motion events into Hubitat. I am a accountant and (you probably guessed it) I'm proud to be dirt cheap. I've already exposed Hubitat virtual switches to Alexa successfully, using Alexa routines to activate the switches, so that seems to be a better way to go for me.
I am already using my three free IFTTT applets to make phone calls to my cell phone (when the fire alarm goes off, when water is detected in my basement and when the Ring Alarm siren goes off). I am hoping Hubitat will do an upgrade and be able to make phone calls.
