I am trying to use Ridiculously Automated Garage Door from ST. But seems getting “null” on cars.find{it.id == evt.deviceId} when state is present…
It is really helpful, when asking for support on a piece of code, to include the code in question in your post. Also include the error message from the Live Log as that usually includes the line number where the error has occurred.
Tip: Please copy and paste the entire App so others can easily help look at the problem. After pasting the code, please highlight/select all of the source code in your post, and then click the Preformatted Text Menu Button that looks like “< / >”.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Ridiculously Automated Garage Door
* Author: SmartThings
* Date: 2013-03-10
* Monitors arrival and departure of car(s) and
* 1) opens door when car arrives,
* 2) closes door after car has departed (for N minutes),
* 3) opens door when car door motion is detected,
* 4) closes door when door was opened due to arrival and interior door is closed.
definition(
name: "Ridiculously Automated Garage Door",
namespace: "smartthings",
author: "SmartThings",
description: "Monitors arrival and departure of car(s) and 1) opens door when car arrives, 2) closes door after car has departed (for N minutes), 3) opens door when car door motion is detected, 4) closes door when door was opened due to arrival and interior door is closed.",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Meta/garage_contact.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Meta/garage_contact@2x.png"
preferences {
section("Garage door") {
input "doorSensor", "capability.contactSensor", title: "Which sensor?"
input "doorSwitch", "capability.momentary", title: "Which switch?"
input "openThreshold", "number", title: "Warn when open longer than (optional)",description: "Number of minutes", required: false
input("recipients", "contact", title: "Send notifications to") {
input "phone", "phone", title: "Warn with text message (optional)", description: "Phone Number", required: false
section("Car(s) using this garage door") {
input "cars", "capability.presenceSensor", title: "Presence sensor", description: "Which car(s)?", multiple: true, required: false
input "carDoorSensors", "capability.accelerationSensor", title: "Car door sensor(s)", description: "Which car(s)?", multiple: true, required: false
section("Interior door (optional)") {
input "interiorDoorSensor", "capability.contactSensor", title: "Contact sensor?", required: false
section("False alarm threshold (defaults to 10 min)") {
input "falseAlarmThreshold", "number", title: "Number of minutes", required: false
def installed() {
log.trace "installed()"
subscribe()
def updated() {
log.trace "updated()"
unsubscribe()
subscribe()
def subscribe() {
// log.debug "present: ${cars.collect{it.displayName + ': ' + it.currentPresence}}"
subscribe(doorSensor, "contact", garageDoorContact)
subscribe(cars, "presence", carPresence)
subscribe(carDoorSensors, "acceleration", accelerationActive)
if (interiorDoorSensor) {
subscribe(interiorDoorSensor, "contact.closed", interiorDoorClosed)
def doorOpenCheck()
final thresholdMinutes = openThreshold
if (thresholdMinutes) {
def currentState = doorSensor.contactState
log.debug "doorOpenCheck"
if (currentState?.value == "open") {
log.debug "open for ${now() - currentState.date.time}, openDoorNotificationSent: ${state.openDoorNotificationSent}"
if (!state.openDoorNotificationSent && now() - currentState.date.time > thresholdMinutes * 60 *1000) {
def msg = "${doorSwitch.displayName} was been open for ${thresholdMinutes} minutes"
log.info msg
if (location.contactBookEnabled) {
sendNotificationToContacts(msg, recipients)
else {
sendPush msg
if (phone) {
sendSms phone, msg
state.openDoorNotificationSent = true
else {
state.openDoorNotificationSent = false
def carPresence(evt)
log.info "$evt.name: $evt.value"
// time in which there must be no "not present" events in order to open the door
final openDoorAwayInterval = falseAlarmThreshold ? falseAlarmThreshold * 60 : 600
if (evt.value == "present") {
// A car comes home
def car = getCar(evt)
def t0 = new Date(now() - (openDoorAwayInterval * 1000))
def states = car.statesSince("presence", t0)
def recentNotPresentState = states.find{it.value == "not present"}
if (recentNotPresentState) {
log.debug "Not opening ${doorSwitch.displayName} since car was not present at ${recentNotPresentState.date}, less than ${openDoorAwayInterval} sec ago"
else {
if (doorSensor.currentContact == "closed") {
openDoor()
sendPush "Opening garage door due to arrival of ${car.displayName}"
state.appOpenedDoor = now()
else {
log.debug "door already open"
else {
// A car departs
if (doorSensor.currentContact == "open") {
closeDoor()
log.debug "Closing ${doorSwitch.displayName} after departure"
sendPush("Closing ${doorSwitch.displayName} after departure")
else {
log.debug "Not closing ${doorSwitch.displayName} because its already closed"
def garageDoorContact(evt)
log.info "garageDoorContact, $evt.name: $evt.value"
if (evt.value == "open") {
schedule("0 * * * * ?", "doorOpenCheck")
else {
unschedule("doorOpenCheck")
def interiorDoorClosed(evt)
log.info "interiorContact, $evt.name: $evt.value"
// time during which closing the interior door will shut the garage door, if the app opened it
final threshold = 15 * 60 * 1000
if (state.appOpenedDoor && now() - state.appOpenedDoor < threshold) {
state.appOpenedDoor = 0
closeDoor()
else {
log.debug "app didn't open door"
def accelerationActive(evt)
log.debug "opening door when car door opened"
openDoor()
private openDoor()
log.debug "opening door"
doorSwitch.push()
private closeDoor()
log.debug "closing door"
doorSwitch.push()
private getCar(evt)
Would be helpful to get a full log when the error happens. The log output on line 113 would help narrow it down. I tested id
and deviceId
both are valid properties and return the correct values. Can you check if cars
is set correctly by clicking the blue i icon next to the installed app and checking the Value column?
Yes all properties are seems to be correct.
However on arrival event
I am getting :errorCannot invoke method statesSince() on null object. on line 135
Added few lines for debugging.
// A car comes home
log.debug "car event ${car}"
log.info "$t0"
log.debug "$states"
log.debug "Not opening ${door.displayName} since car was not present at ${recentNotPresentState.date}, less than ${openDoorAwayInterval} sec ago"
else {
if (door.currentDoor == "closed") {
openDoor()
log.debug "open garage door"
// sendPush "Opening garage door due to arrival of ${car.displayName}"
state.appOpenedDoor = 1
else {
else {
// A car departs
if (door.currentDoor == "open") {
// closeDoor()
log.debug "Closing ${door.displayName} after departure"
// sendPush("Closing ${door.displayName} after departure")
else {
log.debug "Not closing ${door.displayName} because its already closed"
Getting - debug : car event null
I know this is a year old post, but I was wondering if you ever got the garage door app running.
I just got everything set up and I just have a simple rule in rule machine to open our door when my wife or I are present, but I was looking for a more robust solution.
Thaks.
Unfortunately no.
Created rule in RM.
Ok, thanks
