Hi,
I've just moved from Fibaro to Hubitat, mostly things are working well but I am stuck with my Z-WAVE RGBW devices. I have three FIbaro RGBW (441 and 442 versions) and two TKB Home (TZ77) devices controlling RGBW strips around my home. I'm usng the fibaro driver and the generic driver (for the TKB), I can set each colour level (percentage) from the device.
My issue is when I select a colour from the "Set Color" button, the bit where you click the colour you want and it then converts it to Hue, Saturation and Level. When I do this it creates very different colours. This also happens when I enter into the Hue and Saturation direct.
What does work: if I enter for R/G/B = 0/0/100 then I will get 100% blue, same for 100/0/0 for 100% red etc... So it seems to work when I tell it exactly what colour level for each R/B/G to do. So fundamentally it works. But this creates big problems down the line. I cannot create normal "set colour" rules/actions, I have to painfully enter "run custom action" for each Red/Green/Blue/White to get the colour I want.
Scenes set the Hue and Saturation so I can't even use scenes to help.
Has anyone seen this issue? Is it some kind of global setting I've missed? I can't see any other threads on this issue so I assume everyone else has perfectly working RGBW devices.
Thanks,
Jon
