RGBW led controler cant change colors in homekit
Hi all, jumped on the hubitat train and running into a few issues. To give a little bit of background info, I bought a condo in thailand and it came with zwave devices already installed with a weird application on iphone (no siri). The little devices around the house have little to no name where they are from, so I am just trying random drivers to see if it works. I am trying to move the devices over from the old hub to the hubitat.
For the first device to move over to hubitat is a RGB led strip zwave . The driver that works in the hubitat app is RGBGenie LED Controller ZW. However in apple homekit I am not able to change color, unless i go into hubitat app which is too many steps.
I also see three toggles in apple homeview, this is fine as long as I can change color using voice, i can just remove it from homeview. The bed led white and color don't do anything with my rgb led, I can turn them on off change color, the rgb ledstrip doesn't respond on it.
My goal is to make it possible for it to work with "hey siri turn the bed led to color x"
Am I doing things correctly here and is homekit not capable yet of changing colors or am I missing something? Thankssss
`Homekit finds 3 toggles, only bed led works, bed led color and bedled white have no control over the led.
rgbw controller with rgb led, dont think the problem lies in the controller vs strip but just putting it out there.
