RGBW Bulb Recommendation
Wondering if someone could make a recommendation on some smart bulbs. Want to make sure my use case does not cause issues.
I already have Inovelli and/or GE Smart switches on everything so the only thing I want the bulb for is the color changing features. Specifically I want to set my outside bulbs to orange for Halloween, Red/Green for Christmas, you get the idea.
All my current stuff is ZWave Plus exclusively so if possible I want to stick with that but if adding in some zigbee/hue stuff makes more sense I am willing.
So I guess I need to make sure the following:
The bulbs turn back on to the same color/state when the switch turns them off
They need to turn on/off reasonably fast
They do ok in outdoor fixtures (heat/cold and all)
They are not repeaters (at least on my ZWave)
I was considering the Inovelli bulbs but there are so many things about the Hue or Zigbee bulbs I thought I would solicit some opinions first.
Ohh... I guess forget the Inovelli because I just realized they are out of stock and I want to get this done in the next could of days.
Sengled- they are zigbee thu - I use their all their stuff (bulbs, strips, PAR recessed lights, outdoor floods,) and they all work well. They do not repeat.
Thanks for the reply the Sengled look nice - do I have to have a hub to use them with HE? (the zigbee ones I mean)
No. They’re standard ZHA1.2 and pair directly with Hubitat as regular zigbee devices.
Great - ordered 3 - Thanks to both of you
