Is it possoble to reverse this driver so 0 % in level means that it is closed and 100 % that it is open?
I am not a developer, but looking at the code, it seems it would only require switching lines 129 (to result= 100;) and 132 (to result = 0;)
if (value == "off") {
result = 0;
if (value == "on" ) {
result = 100;
Lines 144, 147, 155 & 158 may also need to be updated...
Hmmmm, didn't work......It only revertet the "open" and "close" command. Not the set level command.
Did you just update 129 and 132, or also 144, 147, 155 & 158? I suspect that open & close are 129 and 132 and that the others might invert the set level...
But this is only a guess - I am very much not a developper...
