Reuse AT&T Digital Life Sensors/Devices
Hi all. I shut down my AT&T Digital Life subscription and have cameras, smoke and C/O sensors, water sensors, window and door sensors, etc. I already managed to get my door lock, thermostats, and smart plugs onto Hubitat; wondering if anyone knows how to get the others factory reset and excluded/included into Hubitat?
Make/models would help... (should be on the back)
The AT&T Digital Life sensors are neither z-wave nor zigbee. They use a proprietary frequency.
Why I was asking make/model. Wanted to see what it ran on.
Thanks! The CO Detector is SW-ATT-CO, RTL-41804; the Smoke Detector is manufactured by UTC Fire & Security, model 560NSTTR. I believe someone said the AT&T cameras are proprietary
as well? Just trying to use whatever I still can. Appreciate the assistance!
I also have shut down my digital life system and the sensors are all 433mhz stuff. I think you can get a sonoff something that can read the sensors. However in my playing with them there isn't really a whole lot of security around the sensors. I ended up replacing my stuff with new z-wave sensors.
Smoke, CO, water sensors, contact sensors, etc seem to be all on this 433 thing. The stuff with SW I have found came from secure wireless. I think the cameras can be reset and used like IP cameras but you would need something to record? The locks were tricky but I got them by putting hubitat in exclusion mode then exclude them then include them.
Thanks, all. Appreciate the help. I got my digital life thermostats, lock, and smart outlets all working on my hub, so I'll call that success and replace the other stuff as you suggest; probably not worth tinkering with the 433Mhz stuff
