For shits & giggles, can you try decreasing the sensitivity on the Mighty Mule potentiometer?
Maybe you could try a more indirect trigger using a virtual switch. Use two simple rules, with no conditional statements needed.
Rule 1
Trigger: Driveway sensor ON ##or Closed or whatever it does when it is activated
Action:
Turn virtual switch ON ##no conditional statements here, just do it.
Rule 2
Trigger: Virtual switch on
Action:
Send pushover message ##no conditional statements here, just do it.
Delay 5 minutes
Turn virtual switch OFF
No matter how many times the mighty mule thing triggers, the virtual switch can only turn on once. Once it is on it canāt be turned on again until it is off. So there should only be one trigger going to rule 2, until the virtual switch gets turned off.
I think this should work, should be easy to try it.
Guys, I really appreciate all the ideas. I tried messing with the potentiometer, no joy. I was about to swap out the private boolean for a local variable when I saw @geroose's idea. The clouds immediately parted to reveal rainbows and butterflies. Brilliant and simple solution. All solved. Thank you thank you thank you!
You'll see in that earlier debounce thread that I'm also trying to stop a Mighty Mule from stuttering ...to no avail. Here's a dirty fix;
"Alert,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, vehicle in driveway'"
I get 1 to 3 "Alerts" then the "vehicle in driveway." Sounds OK, and nowhere near as annoying as the previous stuttering.
At the time I posted, I didn't know it worked. That said, I have a bunch of ol' programmer quirks that put me off on that one; I'm not keen on 2 Rules nor virtual devices. (I still tense up every time I type special characters in a text block, hhh.)
Lol pretty sure there are professionals that can help you with that.
