Resumed routine did not run
Last night I resumed a rule I had not used for 6 months but it did not run. I checked the logs and it stated that the rule was paused, but when I open the rule up it shows the pause in the box which I assumed means that the rule has been resumed and should have run.
Anyone else had this problem or know of a fix/remedy.
I am running a C7 on release 2-3-9-184
T.I.I
You will have to show the rule and its logs.
