Does anyone have a way to get a google speaker to resume playing music after a TTS message?
Wife gets very frustrated...Thank you..
Broadcasting is the only way.. and for that you can use for example awesome Google Assistant Relay.
I got lost trying to set this up. Hopefully an easier method comes along, or I have some time to dive into it again with better results.
This same question, only on Sonos, is my #1 home automation request. I swear this used to work 5 years ago just fine with Sonos, but something within their API changed and it's screwed now.
It's too bad that Google can't add this capability. Tried it with my Alexa and it lowers the music level and returns after the TTS message is complete.
My pup has separation anxiety, so when my wife and I leave, we always have Google play continuous dog separation anxiety music. It does work because we check the cams and she is fine. We also use Better Laundry Monitor which lets us know the laundry needs atttention. When the app announces, Google stops playing and doesn’t resume.
So we don’t start the laundry before we leave.
Google does need to resume.
@CurtisZM I have Alexa also. Will use that instead. Thanks for posting!
Haven't tried it recently, but for Sonos "playTextAndRestore" (rather than "Speak") used to work for me.
I found the answer in another thread, if you issue a "Refresh" first, and then "playTextAndRestore" it works (with my limited testing). If I don't issue the refresh first, it doesn't resume/restore.
Tried what, exactly??
playTextAndRestore Not sure if that is relevant to follow me. I'm no coder by no means. If not, my apologies.
Chromecast Integration Beta app doesn't use the playTextAndRestore command, that is for Alexa Speak devices (and others).
Unless Hubitat updates their Chromecast Integration Beta app, we can't resume music on our Google/Nest devices.
Here is my very unsophisticated way of getting around this. I'm getting a couple extra Google Home Mini's. You can find them pretty cheap. I leave the better Google Nest Audio's for my wife and kids to stream music and whatever else they are doing, and put the mini's (with mic disabled) as broadcast-only devices in the same rooms. (activity detected in the garage, etc...). I'll leave the ones my family use off the list of devices to speak notifications to. There are really only two that they use for streaming, and those will be Nest Audio's. The little guys are fine for notifications and we're not talking about a lot of money.
I came to the same solution, but I used the Sonos from Ikea, rather than more GHM/GHN. I put one Sonos upstairs and one downstairs. They are dedicated announcement speakers. It has worked out well. They are more expensive than GHM or GHN (about $100 each) but the Sonos support on Hubitat is rock solid.
is there any way to fix this with a Sonos system
I know this is an older thread but I’m having a similar issue and am new to hubitat. Did you wind up using echo speaks to get it to Alexa?
