C7, 2.3.9.200
So I suspect a corrupted database and want to do a Soft Reset. There are two choices on restore: local or cloud. Are there advantages in choosing one over the other?
I always just use a local when I do a soft reset. And your most recent local backup is likely more recent than your latest cloud backup, if that's a consideration.
But either should work fine.
I would choose local, as the only difference is that the cloud backup can also restore the Zigbee and Z-Wave radio data. Since those are most likely fine, it is safer to use one of the local backup files, which may also be more current.
