[Resolved] Zooz Zen27 Firmware 3.01 not properly being included on C-4 / C-5 Hubs
Hello All.
I finally got around to installing my Zen27's, and I have run into a very interesting "issue" I have a C-4, C-5, and a C-7 (that I will be switching everything over too soon), and I cannot properly add the Zen27 with firmware 3.01 too either the C-4 or C-5. The C-4/C-5 will find the device, but when it is time to save it, it does not know what kind of device it is, and thus does not install a driver. I can manually add the driver, but the C-4/C-5 cannot control the device.
The same device (after properly excluded it and doing a reset on it), will add just fine to the C-7, and is recognized without any issues.
Now, more interesting data. I have a Zen27 with firmware 3.0 that adds just find to the C-4 / C-5, is recognized, etc. I did a firmware update on it (to version 3.01) via the firmware updater tool and I can no longer add it back properly to the C-4/C-5.
Curious if anybody has run into this before. I sent a request to Zooz as well, and will report back.
This is probably redundant, but after changing the driver, did you hit "Configure"?
Thanks for the suggestion. I did, but no go. It is almost like the hub doesn't fully "connect" to the Zen27, and doesn't know what it is.
Quick update. I was able to get it too add to my c-5 (still not recognized as any kind of device), and then try the Zooz Smart Dimmer driver again, and I can now turn off / on the lights, and with a couple of configures it now seems to populate the firmwareVersion. The Current Status doesn't seem to update properly though. (it never updates the status unless I click refresh).
Still testing if it will work on my C-4.
Here is the log output when I included it and did the configures in case this helps.
dev:22021-01-01 03:55:09.887 pm warndescription logging is: true
dev:22021-01-01 03:55:09.886 pm warndebug logging is: true
dev:22021-01-01 03:55:09.885 pm infoupdated...
dev:22021-01-01 03:55:05.520 pm debugManual Control(#15) = 1
dev:22021-01-01 03:55:03.960 pm debugMaximum Brightness Control(#14) = 0
dev:22021-01-01 03:55:02.466 pm debugScene Control(#13) = 1
dev:22021-01-01 03:55:00.880 pm debugDouble Tap Function(#12) = 1
dev:22021-01-01 03:54:59.430 pm debugMaximum Brightness(#11) = 99
dev:22021-01-01 03:54:58.990 pm debugMinimum Brightness(#10) = 1
dev:22021-01-01 03:54:58.776 pm debugDimmer Ramp Rate(#9) = 1
dev:22021-01-01 03:54:58.481 pm debugPower Failure Recovery(#8) = 2
dev:22021-01-01 03:54:58.228 pm debugAuto On Enabled(#5) = 0
dev:22021-01-01 03:54:57.894 pm warnThere are 3 pending changes, please click the Save button again.
dev:22021-01-01 03:54:53.703 pm debugLED Indicator Control(#2) = 0
dev:22021-01-01 03:54:53.436 pm debugPaddle Control(#1) = 0
dev:22021-01-01 03:54:48.284 pm debugFirmware: 3.1
dev:22021-01-01 03:54:47.063 pm debugFirmware: 3.1
dev:22021-01-01 03:54:46.187 pm debugChanging Manual Control(#15) from null to 1
dev:22021-01-01 03:54:46.167 pm debugChanging Maximum Brightness Control(#14) from null to 0
dev:22021-01-01 03:54:46.148 pm debugChanging Scene Control(#13) from 1 to 1
dev:22021-01-01 03:54:46.129 pm debugChanging Double Tap Function(#12) from 1 to 1
dev:22021-01-01 03:54:46.105 pm debugChanging Maximum Brightness(#11) from 99 to 99
dev:22021-01-01 03:54:46.069 pm debugChanging Minimum Brightness(#10) from 1 to 1
dev:22021-01-01 03:54:46.049 pm debugChanging Dimmer Ramp Rate(#9) from 1 to 1
dev:22021-01-01 03:54:46.030 pm debugChanging Power Failure Recovery(#8) from null to 2
dev:22021-01-01 03:54:45.996 pm debugChanging Auto On Enabled(#5) from 0 to 0
dev:22021-01-01 03:54:45.968 pm debugChanging Auto Off Enabled(#3) from 0 to 0
dev:22021-01-01 03:54:45.953 pm debugChanging LED Indicator Control(#2) from 0 to 0
dev:22021-01-01 03:54:45.932 pm debugChanging Paddle Control(#1) from 0 to 0
dev:22021-01-01 03:54:43.792 pm debugconfigure()...
dev:22021-01-01 03:54:31.080 pm warnThere are 3 pending changes, please click the Save button again.
dev:22021-01-01 03:54:26.897 pm debugScene Control(#13) = 1
dev:22021-01-01 03:54:25.487 pm debugDouble Tap Function(#12) = 1
dev:22021-01-01 03:54:23.839 pm debugMaximum Brightness(#11) = 99
dev:22021-01-01 03:54:22.343 pm debugMinimum Brightness(#10) = 1
dev:22021-01-01 03:54:20.831 pm debugDimmer Ramp Rate(#9) = 1
dev:22021-01-01 03:54:19.291 pm debugAuto On Enabled(#5) = 0
dev:22021-01-01 03:54:17.720 pm debugAuto Off Enabled(#3) = 0
dev:22021-01-01 03:54:16.217 pm debugLED Indicator Control(#2) = 0
dev:22021-01-01 03:54:14.699 pm debugPaddle Control(#1) = 0
dev:22021-01-01 03:54:13.186 pm debugFirmware: 3.1
dev:22021-01-01 03:54:12.433 pm infoZen271 switch is off
dev:22021-01-01 03:54:12.430 pm debugSwitchMultilevelReport(value:0)
dev:22021-01-01 03:54:12.153 pm debugChanging Scene Control(#13) from null to 1
dev:22021-01-01 03:54:12.128 pm debugChanging Double Tap Function(#12) from null to 1
dev:22021-01-01 03:54:12.099 pm debugChanging Maximum Brightness(#11) from null to 99
dev:22021-01-01 03:54:12.073 pm debugChanging Minimum Brightness(#10) from null to 1
dev:22021-01-01 03:54:12.048 pm debugChanging Dimmer Ramp Rate(#9) from null to 1
dev:22021-01-01 03:54:12.007 pm debugChanging Auto On Enabled(#5) from null to 0
dev:22021-01-01 03:54:11.973 pm debugChanging Auto Off Enabled(#3) from null to 0
dev:22021-01-01 03:54:11.956 pm debugChanging LED Indicator Control(#2) from null to 0
dev:22021-01-01 03:54:11.889 pm debugChanging Paddle Control(#1) from null to 0
dev:22021-01-01 03:54:11.747 pm debugrefresh()...
dev:22021-01-01 03:54:11.744 pm infoZen271 level is 99%
dev:22021-01-01 03:54:11.737 pm infoZen271 numberOfButtons is 2
dev:22021-01-01 03:54:11.698 pm warndescription logging is: true
dev:22021-01-01 03:54:11.696 pm warndebug logging is: true
dev:22021-01-01 03:54:11.695 pm infoupdated...
dev:22021-01-01 03:53:07.501 pm infofingerprint mfr:"027A", prod:"A000", deviceId:"A002", inClusters:"0x5E,0x26,0x70,0x85,0x8E,0x59,0x55,0x86,0x72,0x5A,0x73,0x5B,0x9F,0x6C,0x7A"
dev:22021-01-01 03:53:07.497 pm debugbuilding fingerprint for unknown Z-Wave device...
dev:22021-01-01 03:53:05.448 pm debugconfigure() called...
dev:22021-01-01 03:51:24.939 pm infofingerprint mfr:"027A", prod:"A000", deviceId:"A002", inClusters:"0x5E,0x26,0x70,0x85,0x8E,0x59,0x55,0x86,0x72,0x5A,0x73,0x5B,0x9F,0x6C,0x7A"
dev:22021-01-01 03:51:24.925 pm debugbuilding fingerprint for unknown Z-Wave device...
sys:12021-01-01 03:51:23.020 pm infoZ-Wave Discovery Stopped
sys:12021-01-01 03:51:23.018 pm infoUnknown Z-Wave Device Discovered
dev:22021-01-01 03:51:22.817 pm debugconfigure() called...
sys:12021-01-01 03:51:16.214 pm infoInitializing Z-Wave Device : 03
sys:12021-01-01 03:51:11.201 pm infoZ-Wave Discovery Running
sys:12021-01-01 03:25:54.114 pm infoUnknown Z-Wave device excluded.
sys:12021-01-01 03:25:29.404 pm infoZ-Wave Exclude Started for 30 Seconds
sys:12021-01-01 03:13:54.574 pm infoZ-Wave Exclude Started for 30 Seconds
sys:12021-01-01 03:13:43.396 pm infoZ-Wave device Tres excluded and removed.
dev:12021-01-01 03:13:16.748 pm warnThere are 3 pending changes, please click the Save button again.
dev:12021-01-01 03:12:08.508 pm infofingerprint mfr:"027A", prod:"A000", deviceId:"A002", inClusters:"0x5E,0x26,0x70,0x85,0x8E,0x59,0x55,0x86,0x72,0x5A,0x73,0x5B,0x9F,0x6C,0x7A"
dev:12021-01-01 03:12:08.480 pm debugbuilding fingerprint for unknown Z-Wave device...
sys:12021-01-01 03:12:06.525 pm infoZ-Wave Discovery Stopped
sys:12021-01-01 03:12:06.523 pm infoUnknown Z-Wave Device Discovered
dev:12021-01-01 03:12:06.289 pm debugconfigure() called...
sys:12021-01-01 03:12:00.663 pm infoInitializing Z-Wave Device : 02
sys:12021-01-01 03:11:56.671 pm infoZ-Wave Discovery Running
Figure I would give another update. I after some fiddling (include/exclude, etc, etc), I was able to get both of my Zen27's connected to my C-4 hub. Once I saved the zooz driver and ran the configure a couple of times it seemed to figure out the switch and all appears working OK.
I do think there is some difference between firmware 3.0 and 3.01 that is making the c-4/c-5 hubs not recognize what the switch is. Version 3.0 worked fine. And so far both versions worked fine out of the box with the C-7 Hub.
