Hey all,
I have an outlet that turns on via a RM - Rule when a door is opened. Another Rule that sees the outlet as being turned on, waits 5 mins then turn the outlet off.
My issue is, the timer is not reset if the door is open sometime later before the 5 mins is up
What is a better way to set this up to allow the timer to be rest when the door is open and only shut off the outlet when a full 5 mins has passed?
Maybe a WebCore Piston is a better way to go, anyone have a sample Piston?
Edit: Here is what I gen'd up, thought?
Thanks in advance
Rick
