Best is arguable - I'm a hack coder. But they are kind of handy if you want more features than the in-box driver. ![]()
Very handy - really love them!
Thanks guys, I will use the generic zwave driver for now and will try the custom Enbrighten driver again later. I do like having the scene functionality that that driver adds.
Some other nice things are:
...and his dimmer driver can turn a dimmer into a switch...like that as I can buy all dimmers and use them wherever I want to and change their functionality between a switch and a dimmer if I change the controlled bulb to a different type. Very cool.
Oh that’s great, love it!
Now, just to confirm, my switch in question here, is the Jasco 46562 switch, not the enbrighten labeled switch, so these custom drivers are suppose to be still good for it?
GE Jasco/Enbrighten/UltraPro, etc., are all the same, just different packaging/marketing.
You can use Jason's Z-Wave Plus drivers w/all of those brands, as long as the particular model fits Jason's info on his driver compatibility w/switch/dimmer models.
@mike.maxwell - this GE/Jasco is getting identified as as a dual outlet, fingerpint updates required I assume.
Got it. Thank you!
can you switch the driver to device and click getInfo?, then past the actual fingerprint listed in live logs, thanks.
Thanks for following up guys @mike.maxwell here you go.
What Hubitat driver does this work with?
We have Generic Z-Wave outlet and Generic Z-Wave Plus Outlet
Mike,
I have it currently set as Generic Z-wave plus switch and seems to be working. After initially it found it as a dual outlet, after cleaning up the outlet child nodes i tried using the Enbrighten custom driver and it wasnt reporting the state well, though the main function of the switch worked, so i changed it the Generic Z-wave plus switch driver.
