I suppose this a reasonable thing to do.
So what if the outage exceeds the hold up time?
And I then there is the constant lead acid battery issues with APC.
Is there a consensus Li-Ion battery bank solution?
You can also point the NTP Device to an Internet based NTP Time server, I believe. You’ll need to figure out the IP address, though.
Wait - how often have you encountered this?
Genuinely curious, because I've had APC UPS units dating back to the early '90s, and I've never had a lead acid battery in an APC UPS leak on me.
I've had batteries lose their capacity to retain a charge and have replaced them when that happens. I have an APC unit at work that dates back to December 1999, and have replaced the batteries in there probably 2 or 3 times. And even that old behemoth remains compatible with apcupsd.
Then, you have to make sure that your Hubitat hub is rebooted after the other devices come back online. No real way around a long-lasting power outage, except a whole home automatic backup generator.
Good point. Also, this is a good reason to use some method of detecting power outages so the Hubitat (and other devices) can be shut down gracefully before backup power runs out.
Hence my use of apcupsd ...
Almost every week where I work, with 80-100 rack-mounted units scattered around the facility in every wiring closet. I just received a new alarm overnight for another APC unit that failed its bi-weekly self-test with less than 2 years on the batteries.
Ever since Schneider took over, APC has definitely jumped the shark.....
Agreed. I refuse to buy APC at work for this same reason.
S.
Nice idea.
I have a GPS-disciplined stratum 1 NTP server on my LAN that provides NTP services to the house regardless of Internet status. I'd like to see this as well.
Regards,
Don
At one point, I pleaded to convert all of the edge closets to equipment that could run on DC from telco-style battery piles to get away from APC. I had one blow me across the room as it threw a plasma-type arc bubble out of the front panel while I was trying to turn it on, with no emergency battery disconnect to shut it down while it went "China Syndrome" other than using a screwdriver to remove the front panel to pull the battery plugs inside the melting down unit! Needless to say, there is no APC in my house.
Also, one "bit" me a few years back while handling the battery pack:
The only good thing about this is that the electrical burn self-cauterized, with no blood lost and no infection.....
You can use @dan.t's NTP client that installs as a driver to set the time on your HE from your own NTPd.
All, with the just release Hubitat version (2.1.5) there is a new function to set the Hub time via an API call. Here is a driver that allows you to specify a local NTP server to retrieve the date/time from and it will update the Hub accordingly. Right now, the driver does NOT support SNTP, only plain old NTP, however. It checks the time on boot and every X minutes (configurable). The configuration should be pretty self-explanatory but I am happy to elaborate if anyone has questions. You d…
Looks like this:
I force an update via NR once a day.
Wow, great! Will try it tonight!
Don
Ouch!
S.
GOOD LORD!!! You developers are AWESOME!! I have never seen this type of support for a device!! I run my own NTP server at home and this was one of my biggest gripes from any other home automation setup, there was no customization of NTP. It would check either a world clock or their own internal clock. Again, Thank you so much for paying so close attention to your community forum for feature requests!!
Wow, this works perfectly!
I have a Stratum 1 GPS disciplined NTP serve on the local LAN. It's actually part of a lightning detection network that use nanosecond-level accuracy GPS time to measure the arrival time of detected lighting strikes all over the world and triangulate those with detected events from other stations. The local NTP is an added feature of the unit.
The unit use the PPS rising edge signal to get the nanosecond-level accuracy. This NTP code can't do that, but even with the local delays in the LAN and devices, I'm getting 35 ms difference between NTP and Hubitat time.
Great job and many thanks!
Via an API call in the driver code - no enabling necessary. After saving the driver code, Create a virtual device and change it to the code then fill in the properties and you should be good to go.
OK so I am new to this...
So I save the code as text file somewhere, then create a virtual device, and 'change it to the code' does that mean paste the code into the device somehow? I will play around with this, but it's not that clear to me (yet) I mean I could always rtfm right?
Never said leak. But I would prefer at this point in consumer energy storage to move to Li-Ion. Wait-what? Did I say that? Talk about little fires everywhere.
At work (power electronics / industrial) Schneider's Li-Ion rack based UPS is pretty impressive - with ModbusTCP built in. But it's a bit pricey for home use. What is more I need UPS at several places, for RPis, NASs, and a DVR backend, and now the Hubitat. I ordered (4) yesterday - and reading the reviews it seems like a crap shoot.
Great job
To be clear, the great job was by @dan.t - he wrote the NTP client. I just linked to it in this thread.
OK I rtfm'd. Virtual Device is in the Hub
Need to setup an ntp server - think I'll use the pvr backend windoze box for that.
Thanks much Hubitat denizens.
You "import" the code. Click on Drivers Code in the Left Menu and then New Driver, top right.
You've followed a Link to a github repository for the NTP Code. You click RAW and then 1) select all the code to copy. then paste that into the HUb's driver code window, click Save. OR 2) you select the URL for the raw code, and on the Hub, click IMPORT. Paste the github URL into the Import box and click Import. Click OK, then Click Save
With the Code on the Hub, you create a virtual device, and give it a name. Then click the list of drivers adn scroll to the very end/bottom. User imported code is always at the very end. You'll see the NTP driver there and select it. Click Save Device and you'll be taken to the device Info page, where you can fill in the blanks.
Thanks much, I found the help topic that walked me through it. I have it setup.
Hot damn tomale....
Current States
lastDiffMS : 932
lastHubDate : Mon May 25 11:16:10 EDT 2020
lastNTPdate : Mon May 25 11:16:11 EDT 2020
updateHubTimeTo : Mon May 25 11:16:11 EDT 2020
