Requesting support for color lights on HSM light alerts. I use Blue for water, red for fire and green/yellow for alarm with ST.
We will evaluate this possibility.
Same here. It would be awesome if there was an option for “Button to Clear alert” as well that would reset the lights to it’s previous state. This is essentially how it worked on SmartThings for me.
Wouldn’t any switch that controls the lights do the same? You’d have to build in a reset to white function to your switch on, but that seems easier than trying to store and restore from within HSM
I do have a reset for my lights but that is for my defaults. There are times when I have a custom lighting that may be manually configured and don’t want to reset the light but just have it go back to the setting before the alert. I don’t know whether it would be difficult or worth the time to code but it would be appreciated. Can’t hurt to ask.
You can do this with a simple trigger in Rule Machine. In fact, you can use a triggering device (switch, contact, motion, button, etc...) to Cancel Alerts.
Also, you can do this with Button Controller -- Cancel Alerts is a supported action for any button.
Saw it on the new update. Thank you for adding this option!
