It is my understanding that Wi-Fi and Thread require two separate radios. Is it technically feasible to repurpose the C8 Wi-Fi radio to support Thread if the C8 installation does not require Wi-Fi? Both operate in the same 2.4 Ghz range.
That would be the Zigbee chip. While theoretically possible, not so much feasible.
I'm not aware of any Wi-Fi chips that can do double-duty as Thread (or Zigbee), though some Zigbee chips can. However, that is not part of the plan. I see you're a beta member, so you should be able to see some discussion, including this: https://community.hubitat.com/t/2-3-7-matter-beta/126457/66 (note to others: if you're not in beta, you won't be able to see this, but spoiler alert: the answer is the same
